Bill-CollaborativeMT Posted January 27, 2019 Share Posted January 27, 2019 Newbie Problem: In VWA 2019 I am not able to run the subtract solids command on two generic solids. But, if I group the two objects, edit the group, then run subtract solids command, then ungroup the created object I can. Is this expected behavior? Quote Link to comment
Benson Shaw Posted January 29, 2019 Share Posted January 29, 2019 That is not the intended workflow, but glad you found a workaround. I cannot reproduce the problem. My generic solids add without grouping. Can you post a file here so we can look? -B Quote Link to comment
Marionette Maven Marissa Farrell Posted January 29, 2019 Marionette Maven Share Posted January 29, 2019 @CollaborativeMT Are your objects on the same layer? I believe it's necessary that they are in order to run the command. By grouping them, you force them onto the same layer which is why that would work. 1 Quote Link to comment
