CollaborativeMT
Solid subtraction of generic solids
Newbie Problem: In VWA 2019 I am not able to run the subtract solids command on two generic solids. But, if I group the two objects, edit the group, then run subtract solids command, then ungroup the created object I can. Is this expected behavior?
That is not the intended workflow, but glad you found a workaround.
I cannot reproduce the problem.  My generic solids add without grouping.
Can you post a file here so we can look?
-B
