Create Roof. Fixed at last. Nearly.....?
In previous iterations of the very helpful create roof tool it is possible to add components so you could effectively depict a thinner tile layer on top of roof rafters, AND enable the tile component to protrude beyond the eaves. However if you ungrouped the roof to redesign it the programme would assume every side of each sub roof face required this protrusion which is not the case, making for a very messy roof.After 3 years I re-attempted this operation today and pleased to discover this issue has been fixed, saving me hours of time in the future using 2 roofs to achieve the same effect.   However when I attempt to render the tile (only) element the entire roof renders (understandably) and when I try to render the component only which the programme allows you to do, the operation does not seem to work? Or am I missing something? The effect I'm after is in the roof images to the right (just got planning permission after 8 weeks of planning department hell involving us having to depict a bush! A BUSH ! This was achieved with 2 separate roof faces per roof) and the operations I have been describing are in the image to the left. Any feedback gratefully received. D
Morning Mr Cadplan. I've often wondered how one can see what versions and graphics others are using because we fill that data in but I can't see it? I'm on 2019 SP2 Architect. I try for a bespoke watercolour effect so that our clients do not get distracted by photo realism when we are trying to get them to buy into the space and design we are creating. First off, any textures used I dumb down by exporting to Photoshop and adjusting the hue & saturation and re-import back. The windows are on Glass figured light blue. Ambient Occlusion on high. The render settings are attached....Other than that the real devil is in the detail! And the heliodon shadows of course. I can't take the credit for the render it was created for me by @Tamsin Slatter
I have not included the bush which enabled the scheme to get planning for fear of embarrassing our local planning department because as everybody knows, common or garden bushes are really important to any design acceptability 🙂
I'm still none the wiser regarding the create roof rendering.  😞
D
Hey that's great so thank you, I know that Tamsin is an expert so that must have helped a lot. I use VW2016 and may try the relevant render settings.
I can't really help with your roof question, I've tended to stay away from modelling complex roofs party due to the 2016 limitations and also the time involved which for most jobs isn't economic.
Thanks again
Andrew
16 hours ago, David S said:
Not if you are after the holy grail of a tri-panneled door? 🙂
Well as someone who specialises in house extensions, 50% of our jobs involve opening up the back wall of the house then adding a large ground floor extension with bifold doors bedtween 2.5m and 5.5m wide, it's embarrasing to have to tell people that VW only allows for two or four leafs.  We could draw them manually but it's a faff  and doesn't feel right. I've been asking Vectorworks about this for many years along with others  (wishlist) but it seems to fall on deaf ears unfortunately  I'll probably be packed up before it happens!
52 minutes ago, David S said:
Yes. I see! . We are currently being hounded by 2 local councils to undertake "pre-apps" This is where they tell you prior to submission what they will allow, effectively shutting design doors before they have even opened. Is it the same down your way?
pre apps for house extensions is largely an unporoductive and time wasting exercise so we rarely do it, we prefer to use our experience to advise clients what we think would be acceptable and then negotiate with the plkanners later if necessary
