David Dauphin
More fields in "Truss record" Database
Hello,
A question to Vectorworks Spotlight developers :
Could it be possible to have more fields in truss record database? It may be useful to have connections forks needed for the system, and total volume of system.
I used to work with truss symbol instead of spotlight truss, and all my trusses have connections forks quantities (2 for ladder truss, 3 for triangle truss, 4 for square truss, 1x2 or 1x3 or 1x4 for 2D corner, 2x2 or 2x3 or 2x4 for 3D and 4D corners, ...). And then, order picker in stock have exact quantity of each truss and total connections forks needed.
Volume may be useful too, to approximatly know what trucks size needed (20m3, 30m3, 40m3, ...100m3)
Yes I know that I could duplicate spotlight truss libraries and customize them using "User fields 1", 2, 3, ... But it may be  useful for everyone to have those fields, no?
Many thanks to ear this request.
Here an example of old system build with truss symbol (and no spotlight truss tool). Connections forks are "Goupilles & sécu en sus", and volume is "Cubage colisé" in my french worksheet :
53579073_tableau-truss-erreurtotallongueurexsymbole.thumb.png.75d97b65cc38329e26014ff4409077f3.png
If there is enough of a desire for this data, we can see about adding to the record for it, but it will take a while for us to go through all the libraries and add it in.
Several years ago I was at a meeting of the minds of several European power users, and there were many different data points they wanted added, but no agreement on what things were the most important.  This is how we ended up with the 6 user fields, this gave them added data points for whatever they needed.
We are happy to adjust things as time goes on for our user base, but the amount of work needs to coincide with the user base that needs the addeddata and the time it will take to implement, which also means time away from other content addition or updates.
Thanks Rob,
I understand your contraints. No problem. Other questions : to do that on my own, is it the correct way :
I had to duplicate a truss library in /Applications/Vectorworks 2019 FR-FR/Bibliothèque/Objects - Ent Truss/....,
- edit this duplicate files with my personnal user fileds data to have my worksheet with the data I need
And after I can use this duplicate files in Spotlight AND Braceworks too?
The disavantage is I had to edit duplicate files each time that there's an update on original libraries?
I would not keep them in that folder, if you keep a duplicated file in your user library folder (you can find the location on your computer through Tools>Options>Vectorworks Preferences>User Files tab), then this will not get overwritten by any updates.  you would need to do this again with new files, but you should be fine as long as they are not in the downloaded folders for content, then they might be overwritten if an update comes through.  and you can keep those files in the RM through the User Libraries tab.
and yes, once you add your user data, the files will still work correctly in VW and Braceworks.
Hi David.
I am currently using custom records to add 'rigging hardware' such as spansets and shackles to elements of truss so that they report into a worksheet. It may cover some (but not all) of the functionality you require.
Best
Tom
Timing is everything. I'm just now adding truss records to the generic cheeseborough object so I can count them within my truss counting worksheets. I'm searching for a method of copy/paste the same record, with all the info filled in, from one clamp to the next.
@TomWhiteLight Hi Tom,
I'm curious, what does your record look like? Do you also attach to your truss? I'm doing the same, but using the truss record itself.
Thanks, Scott
10 hours ago, TomWhiteLight said:
Hi David.
Best
Tom
Thanks Tom. OK I will do like that too.
Sorry, my english is not so good, and Google can't traduct "the generic cheeseborough object" in french. Can you explain me or show me a screenshot please ?
Hi Scott. My slightly incorrect but still relevant to this issue.. Attached records are for Hoist Data and are formatted in the following way...
High Hook Rigging Point (Type Pop up) Choice of Gravlock/Ibeam clamp or Roundsling/Strop
High Hook Motor Attachment 1 (Type Pop up) Choice of Hoop or Bow Shackles at varying ratings
High Hook Motor Attachment 2 (Type Pop up) Choice of Hoop or Bow Shackles at varying ratings
Low Hook Rigging Point (Type Pop up) Choice of Roundsling/Strop or Prolyte style Truss Hanger
Low Hook Motor Attachment 1 (Type Pop up) Choice of Hoop or Bow Shackles at varying ratings
Low Hook Motor Attachment 2 (Type Pop up) Choice of Hoop or Bow Shackles at varying ratings
I have started experimenting with Underslung/Overslung Truss connections and I am working on a record that works in a following way.
Onstage Chord Hardware 1 (Type Pop up) Choice Doughty Half Coupler Fixed/Doughty Half Coupler Swivel/Scaff Clip 90/Scaff Clip Swivel
Onstage Chord Hardware 2 (Type Pop up)  Choice Doughty Half Coupler Fixed/Doughty Half Coupler Swivel/Scaff Clip 90/Scaff Clip Swivel
Offstage Chord Hardware 1 (Type Pop up)  Choice Doughty Half Coupler Fixed/Doughty Half Coupler Swivel/Scaff Clip 90/Scaff Clip Swivel
Offstage Chord Hardware 2 (Type Pop up)  Choice Doughty Half Coupler Fixed/Doughty Half Coupler Swivel/Scaff Clip 90/Scaff Clip Swivel
Safety Option (Type Pop up) Choice, Steel lengths or inertia truss safety chord options.
All the best
Tom W
