I find that the default Title font (14) and the default Drawing # size (12) are not good for my drawings.
I would like to set it up so if I am doing a 1/4" scale drawing and create a label in the viewport the Title is 16 the # is 16 and the rest are the same
If I am using it in 1/2" scale I would like the default to be Title 20 and # 18.
I wouldn't mind creating the default each drawing and just have it do it for every viewport label. It is time consuming to change them every time I create a viewport. That's 2 extra steps.
Speaking of which, when making a viewport I would like it to be able to use a set scale that I am doing for everyone instead of 1:1 each time I make a view[ort, no I don't draft in scale I draft in 1:1 because I work with sketch up and DWG files and find I have more problems with scale than I do with 1:1.
Talked with Tech support they said there was no way to do either.
MartinFahrer
Thanks in advance
Martin
10 answers to this question
