No transparency control for slabs anymore in 2019
elepp
Hi folks,
is it possible that the controls for transparency in the slab tool were removed? No slider and no button to set it to by class.
Peculiar to remove something like this.
We generally use it to make the slabs semi-transparent in Plan View. It's less disturbing than having a black slab in Plan View.
Regards,
elepp
  • Marissa Farrell changed the title to No transparancy control for slabs anymore in 2019
Thanks for the info. But maybe I am misunderstanding, where exactly would you adjust the opacity of the slab?
Edit: Sorry, was sitting on my eyes (a typical response in germany for not seeing the obvious thing :D) I get it now. Somehow I was looking in the wrong spot. 🙂
Edited by elepp
1 hour ago, elepp said:
A pity it got removed, but will do for now. Thanks a lot for the quick replys.
It had to be removed from the Styles, otherwise if you wanted one slab transparent and another drawn normally, youd have to create a whole new style just for that purpose.
  • Marissa Farrell changed the title to No transparency control for slabs anymore in 2019
