Phileas Posted January 21, 2019 Share Posted January 21, 2019 (edited) Hey so I'm working on the water evacuation system of a terrace, and I've encountered a problem that I believe is impossible to solve with the slab drainage tool: This is a quick sketch of what the slab looks like. Now here comes the problem: This terrace is on the first floor, so the sides of the slab you see here need to be joined to the concrete slab of the first floor of the house. To do so without creating an insulation problem with the heated rooms below, this joint needs to be done using "thermal consoles" (or I don't know how you call them in english, basically 8cm thick insulation panels with steel beams, capable of carrying the weight of the terrace just like normal concrete). Thing is, these thermal consoles have a fixed height, and can only be joined to a slab with the exact thickness matching this height. So all the sides of my terrace slab need to be exactly 22cm thick. So what I would want to do in VW would be to somehow tell the program "OK so all the sides of this slab are 22cm thick, the drain is 7cm lower, please adjust the slopes so they match these requirements". With the slab drainage tool, I can adjust the desired maximum thickness value of the slab, the altitude of the drain, and the slopes by hand. The point is, I have no way to ultimately fix the thickness of the edges of the slab and have the slopes calculated by VW, I can only fix the slopes and then have the thickness calculated, which is useless to me here. So if anyone has a solution for this (other than creating a 3D-Object counterpart to my slab and then use the "substract 3D Object from slab" command), please let me know. If there is no real solution, then I'd like to know where I can add this feature to the wish lists for future versions of VW. Also for the wish list: The automatic cotations of the slopes that are generated by the slab drainage tool are impossible to move around properly, and the only way to edit them somehow is through classes. I'd like to be able to edit them like normal text characters, that would make everything much easier. Edited January 21, 2019 by Phileas Quote Link to comment
Hans-Olav Posted January 21, 2019 Share Posted January 21, 2019 Hi If you define a slabstyle with the thikness of the slab at the drain 220-70=150mm then place the drain where you want it and later edit the endpoints to 70 mm. do you get what you want? 2 Quote Link to comment
Phileas Posted January 21, 2019 Author Share Posted January 21, 2019 @Hans-Olav How do you edit the endpoints of a slab? I've never seen a dialogue box where you can set a thickness for a particular spot of a slab Quote Link to comment
Hans-Olav Posted January 21, 2019 Share Posted January 21, 2019 If you go to edit mode you can right click the blue selection handle and choose some options 3 Quote Link to comment
Phileas Posted January 21, 2019 Author Share Posted January 21, 2019 @Hans-Olav Embarrassing confession time: This is exactly what I wanted to do this whole time, but it never actually crossed my mind to try and right-click the blue handles. I right-clicked the drain probably 250 times, but never thought of trying to click the handles 😞 I feel stupid lmao Thanks man you saved me again, if I could I'd like your comments ten times 😉 1 Quote Link to comment
