Accessing Object Data in another file
twk
You can extract data from a resource in another file, but not an object. If you create a reference to the other file and a referenced viewport, you should be able to read the data via the viewport.
The only other option would be to have the file write data to an external data source (xml, text, sql, etc).
Wondering how 2019 does it with titleblock data being able to read TB info from another file?
Could not find any related functions for opening one file in another file in the DevWiki or the SDK files.
Edited by twk
I don't know 100% the process, but a lot of the title block data gets written to a hidden record format, and I imagine this is what gets read.  (Essentially writing to the record format's defaults).  You can browse the file's resource list, import the record format, read the data, then delete.
