Charlie Winter
Assign Class to Selected Symbol via Custom Script
Is it possible for a script to assign a specified class (written into the script) to single or multiple selected Lighting Device Objets?
Edited by Charlie Winter
A single object is easy:
SetClass( FSActLayer, ‘Class Name’ );
All select objects takes a bit more code structure. Look at ForEachObjectInList, which will iterate through objects. You can set the function to traverse all selected objects.
So what Josh is referring to is a structure like this, which is one of the most time saving scripts you can have because it can be adapted to do so many things::
Procedure TimeSaver;
Procedure DoIt(h1 : HANDLE);
BEGIN
SetClass( h1, ‘Class Name’ );
END;
BEGIN
ForEachObject(DoIt, (Sel = True));
END;
Run(TimeSaver);
