Jeremiah Russell 7 Posted January 15 Lord give me strength. Can someone tell me why all my wall intersections are un-joining when I open the file? It's really getting annoying to spend hours every week re-joining my walls on a 145,000sf multifamily project. Share this post Link to post
Matt Panzer 186 Posted January 16 Hi Jeremiah, Do you have any idea what might be triggering the problem? Are you using Project Sharing, Design Layer Referencing, and/or Design Layer Reference Viewports? Share this post Link to post
Jeremiah Russell 7 Posted January 16 @Matt Panzer I do not have any idea what might be causing the problem. I am using Project Sharing, though it isn't necessary right now. I am using Design Layer Referencing but not within the building model. The references are for 2D details on separate design layers not tied to stories. Any help would be appreciated. Thank you. Share this post Link to post
Matt Panzer 186 Posted January 16 Unfortunately, I do not know what causes this. We are, however, trying to figure out what triggers this problem. We have not been able to get a reproducible case but we are currently testing for this (and other project sharing related issues). I certainly understand your frustration and want this issue resolved. Do you know if this happens after you "Save and Commit", close the working file, and then reopen it? If you have any idea what triggers the problem, please let me know. One more question: Are the walls becoming completely unjoined or is it custom component joins that come undone? Share this post Link to post
Jeremiah Russell 7 Posted January 16 @Matt Panzer It's generally noticed after I have have saved, committed and closed the file then come back to the working file. I do not notice it happening while I'm working in the file. However that's not to say it doesn't happen. One thing I can think of is that all my wall types are different. This particular project is an old historic masonry building and so I have about 15 different wall thicknesses all as their own wall style but with the same class and texture assignments. There are also a fair number of wall projection elements for pilasters at the perimeter of the exterior walls. That may or may not have something to do with it. Thanks! Share this post Link to post
Matt Panzer 186 Posted January 16 @Jeremiah Russell, Thank you for the information. This will be helpful as we continue testing! What about my last question: Are the walls becoming completely unjoined or is it only custom component joins that come undone? Share this post Link to post
Jeremiah Russell 7 Posted January 16 @Matt Panzer The entire wall comes unjoined. I don't know what custom component joins are. I use the join wall tool, not the join component tool. Is that what you meant? Share this post Link to post
TomKen 7 Posted January 16 I am also playing whack-a-mole rejoining walls. This happens when using project sharing, we have four people working on the same project. I have no idea what triggers the problem though. 1 Share this post Link to post
Matt Panzer 186 Posted January 16 10 minutes ago, Jeremiah Russell said: @Matt Panzer The entire wall comes unjoined. I don't know what custom component joins are. I use the join wall tool, not the join component tool. Is that what you meant? Yes. That's what I meant. Thank you. I suspected that was the case. Share this post Link to post
Tolu 10 Posted January 17 @tomk @Jeremiah Russell Hi Jeremiah and TomKen, Are the walls that become unjoined all on the same layer, same classes? Do you know if those walls were recently modified? Thanks. Share this post Link to post
TomKen 7 Posted January 17 Tolu, The walls are all on the same layer, Some are Wall Exterior Class, and other are Wall Interior. Walls of the same class and different classes both come unjoined. The walls in the attached image were all joined the last time I looked at them. Share this post Link to post
Hans-Olav 55 Posted January 17 Hello We have seen similar issues in a project file recently, 3 persons working at the same time. Suddenly walls on several floors became unjoined and some misplaced. We recreated the file from an earlier backup and copied newer elements over to get back on track. I forgot to save the problem file I can't really tell what caused it but we were in a phase discussing color and material use in the exterior. Me ( the admin ) was changing textures on wall styles to evaluate different color options. Meanwhile a coworker was dimension walls and openings on different layers. There was no warnings or messages displayed but suddenly a lot of wall got unjoined. I suspect fiddling with textures used on wall styles forced some walls to update on several layers and can be part of the problem also the dimensions associated to wall ends and openings. Share this post Link to post
JMR 105 Posted January 18 We encountered this issue with 2018 SP0-5, on project sharing. After the PS-phase was completed, the walls have remained joined, at least so far. On VW2019 we haven'tried PS yet. The only thing I could pinpoint at the time was the save/commit/refresh process: Workstation 1 displayed nicely joined walls, but workstations 2 and 3 unjoined them at refresh. What is baffling, the unjoins were not the same on different machines. Additionally, no intentional user operations on walls or wall styles were necessary for the unjoin to happen - simply refreshing the PF after doing anything at all on one of the workstations. The workaround was to save the project as .vwx from workstation 1, then reshare-it. Share this post Link to post
