Script Repeats from Worksheet Recalculate
Hello,
I've managed to get back onto scripting and sifted through examples online then made a script which changes the cell text in a worksheet from a design layer pull down menu. However when i select the worksheet image and recalculate it, it then repeats. If i select the individual cell and hit enter it executes once and works fine however the rest of worksheet does not update because the criteria is set to use the cell's result from the script as the layer name to look for. Thankfully i've had allot of references on here to refer to but i'm very new to this so i totally understand if it is not laid out correctly. Any suggestions, anyone?
Thank you
Test Worksheet script.vwx
