khumenny
VW 2019 Crash on Quit
 I’ve had this problem for a while, when I “quit” VW the windows close then I get the spinning wheel for a long time and I have to “force quit” and it says VW is not responding.
14 answers to this question
@Tmorgan So, Can you Resetting Vectorworks Preferences.
The preferences, plant database, workspaces (etc.) are located in the HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks > 2019 folder.
The Library folder for your User account is hidden. The easiest way to display it is to open Finder, then hold down the alt/option key on your keyboard while clicking "Go" from the menu bar, then selecting "Library"
1) Go to this folder found in 'HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks' (I Will Recommend Back Up This folder (2019) First, in other folder) Delete the 2019 Folder
2) Empty the trash, then reboot your computer. If the trash will not empty because a file is in use, reboot before emptying it again.
Ps: I edited this information above, from this article.
That did not work.
And I have to get my templates, blocks and settings back in.
If this is a great mystery to VWX then I am going to leave it alone and keep Force Quitting.
Thank you for trying.
@Tmorgan Copy your older folder (2019) That I recommended backup in (HD > Users > (User's Home Folder) > Library > Application Support > Vectorworks) . And your templates, blocks and user settings come back.
Sorry, if I have any Idea to help you in this case, I Will share with you.
Edited by Paulo Ferrari
@Tmorgan But it's very strange this problem. I have Vectorworks 2019 since SP0, in both System (Windows and Mac), and this problem never happened with me.
My Mac Specs, it's huge worst that your MacBook.
Thank you again.
i did not have this problem on my older MacBook. My boss had this problem and says it started closing fine seemingly out of the blue.
Hi @Tmorgan,
When you say that you get the spinning ball for "a long time", how long have you left it?  If you leave it for longer, does it ever close without having to force quit?
Please can you try running the repair tool.  This will be found in the program folder which by default can be located in Applications > Vectorworks 2019 > Vectorworks 2019 Updater > Advanced Options > hold Alt/Option and click Repair.
