Phileas Posted January 11, 2019 Share Posted January 11, 2019 I wanted to know if it is possible to set the options of a 3D Object (an extrude for example) in a way that the Extrude would show a fill in a vertical section view, like floor slabs do. Quote Link to comment
Hans-Olav Posted January 11, 2019 Share Posted January 11, 2019 Hi Phileas First your extrude must have a fill and secondly you have to go into the advanced section properties and choose "Use attributes of original Objects" 1 Quote Link to comment
Phileas Posted January 11, 2019 Author Share Posted January 11, 2019 @Hans-Olav Thank you very much! Do you happen to know how I assign a fill to a 3D Object? Quote Link to comment
Hans-Olav Posted January 11, 2019 Share Posted January 11, 2019 Use the attributes pallet on the design layer you will have to be in open gl rendering mode to see if a 3D object is filled Quote Link to comment
Phileas Posted January 11, 2019 Author Share Posted January 11, 2019 @Hans-Olav worked perfectly 🙂 I wanted to thank you for helping me so much recently, I'm quite a newbie to Vectorworks and still learning 2 Quote Link to comment
