ADJUST FLIPPED TEXT TOGGLE NOT AFFECTING ALL OBJECTS
B Cox
I'm having an issue with VW2019 SP2. I usually work with 'adjust flipped text' turned off. However, text inside my annotates is still flipped/rotated etc. VW does not properly show me the condition of the text, so I have to blindly export my sheets to PDF to truly see the condition of my text.
Does anyone else have this problem?
I also noticed another stupid problem in VW2019 SP2--if you do duplicate along path on a closed path (like circle or ellipse) it doesnt use your original object as the initial position. You have to split the path or you end up with random but equal positioning of generated duplicates.
1 answer to this question
