VW 2019-The symbol does not react on class selection
oien
3 answers to this question
You're correct. It seems that the class visibility function will not work when using "Merge Cross Sections" and "Separate Cross Sections" from an attribute class. I think that this must be a bug as it seems odd that it is "working as designed". I can't seem to make the Add Profile Line work either.......
Will you submit this a s a bug?
The Add Profile option adds a profile around only structural objects (walls, stairs, slabs, roofs, etc). You can also select the "Merge with Structural Objects in Sections" in the Object Info palette of 3D objects and they will also get the profile line.
