david p Posted February 9, 2005 Share Posted February 9, 2005 Hello, I copied a hatch pattern (concrete) and changed the scale. Now the pattern doesn't look like the original concrete pattern. I believe that it has something to do with the dash factor. Also, when I'm in the edit dialog box of the hatch the preview and the final hatch are different. Thanks, David Quote Link to comment
jfmarch Posted February 9, 2005 Share Posted February 9, 2005 when you changed the scale, did you change all the levels within the hatch, or just the active one? Quote Link to comment
david p Posted February 9, 2005 Author Share Posted February 9, 2005 I have been working on this and have tried a few different things... drawing "A" has the correct concrete hatch In drawing "B" I go to the Resource Browser and drag & drop the concrete hatch into the drawing. At that point the concrete hatch has already changed. I'm not sure how to fix this problem? thanks jfmarch, anymore ideas? David Quote Link to comment
david p Posted February 9, 2005 Author Share Posted February 9, 2005 hatches: Associative and Static problem w/ the Attribute palette... i used the Tool menu and the concrete hatch seems to work... Quote Link to comment
jfmarch Posted February 9, 2005 Share Posted February 9, 2005 try to import the hatch with the option to replace... Quote Link to comment
