DomC Posted December 20, 2018 Share Posted December 20, 2018 (edited) Hello I used my own "set layer" node in past. More recently the default library has a node "Set Layer". Did I understand it wrong or do this node just nothing? # The code in the node of default library l = self.Params.layer.value o = self.Params.object.value #script layer = vs.GetObject(l) #get layer handle of input layer name obj = vs.GetParent(o) #get parent of object input (obj = existing layer) vs.SetParent(obj, layer)#set existing layer to new layer that works? #outputs self.Params.obj.value = o As I understand, this code set the new layer as the parent of the existing layer. I think something like this, would be better, or not? #script layer = vs.GetObject(l) #obj = vs.GetParent(o) vs.SetParent(o, layer) Test Set Layer.vwx Edited December 20, 2018 by DomC Quote Link to comment
Marionette Maven Marissa Farrell Posted December 20, 2018 Marionette Maven Share Posted December 20, 2018 I think the default content node is missing a check to see if the parent of the object is a Marionette generated group or a layer. In the case of a Marionette created object (for instance a rectangle drawn with the rectangle node) we need to move its parent group to the appropriate layer so that when the network is rerun the object gets replaced. 1 Quote Link to comment
DomC Posted December 20, 2018 Author Share Posted December 20, 2018 Hi Marissa Thank for that quick reply. Quote object is a Marionette generated group or a layer. Aha, now I understand the additional parent check. Quote Link to comment
