cmpatten
Connecting line visibility with "Change Plant Grouping” function
The connecting line visibility does not appear using the "Change Plant Grouping” function.
•  Use the Single Plant Placement Mode and insert several plants. Use the Change Plant Grouping tool from the Landmark menu. The plants will group but NO line connecting these plants will appear.
•  Insert plants using the Poly-vertex Placement Mode or Poly Edge Spaced Mode or Rectangular Array Mode or Triangular Array Mode, the line appears.
•  Use the Change Plant Grouping function again on any of the above placement modes and the line dissappears like it always has done., BUT use the Change Plant Grouping function again on the same plants and the line will not re-appear.
I have done the same thing using VW 18, (and even VW2008) and the visible lines connecting the plants re-appear (like always). Also it didn’t matter whether the polygon display was set to solid or none, the visible line could always added later if desired.
Any thoughts or is this already on a fix list?
