Eyedropper & Wall Attributes
Jim Smith
4 answers to this question
Jim,
Another quirk is that if you use the eyedropper between walls, but click "cancel" when the wall component matching dialog opens textures will still be applied to the second wall.  I don't think the program is intended to work this way, but I often use it as a quick method of moving textures between walls when I need to.
We tried to adopt stories a few times and ran into so many problems that we ignore that part of the workflow opting instead to manually offset components, etc.  So far - I think it has been the right choice.
On the other hand, I'm happy to hear that you are dedicating some time to provide habitat for the elusive unicorns.  Their needs are often overlooked.
