archdaly
Door Schedule Prefix?
Does anyone know how to remove the HM prefix in the VW generated door schedule for door and frame material? The cell is editable but I can't get rid of the "HM" in front of it...
10 answers to this question
Archdaly,
I assume that you tried to type directly into the worksheet.
Try selecting the door and then in the OIP - click on "Settings"
In the settings, select the "Data" tab at the bottom of the list and try and enter your data there.
If that doesn't work, the doors may be styled - so that they all retain the same labeling ...
If you post an example file with that schedule in it, we may be able to figure out what is going on.
Thanks Taproot... the screenshot that I uploaded is what I'm referring to. I have modified the data field for the door to simply have "WD" and not HMWD. Editing the worksheet directly works as well to change the suffix but the HM remains regardless of what I input into the field.
Doors are all unstyled...
If you can post the file, or copy a few doors and the schedule into a blank file, I'll take a look at it.
Archdaly,
Those two columns appear to be corrupted.  I was able to solve the problem by creating two new columns and then copying and pasting your original criteria (in the database header row) to them.
Attached is your test file with that update.  The original two columns are shaded - you can delete them.  The working columns are unshaded.
Cheers.
TEST2.vwx
Taproot is there an easier way to edit the material in the worksheet rather than having to input data for each door type?
Thanks,
I can't say that I understand your question.
If you are asking how to speed up data entry, you can of course copy and paste between cells.
NM I got it... I think there might be something glitching. The edit field is greyed out but I'm able to copy/paste directly in the cell.
I think I'm getting the hang of it!
