In the attached photo is a custom position label symbol, with a custom record format. I am experiencing an issue where the symbol does not refresh to its previous data when executing the undo command.
The top symbol shows the 'Position Label Field' with the default value P-##, and the bottom field shows the 'Position Label Field' with the modified value from the Spotlight Numbering tool, using the Object with Record option, 1.
For this example I executed the undo command, and as you'll see in the OIP it reverts to the original field data, however a nudge will be required to refresh the symbol so it will update.
The action of nudging symbols after undoing a numbering action is not ideal.
Charlie Winter
Has anyone else had this experience?
0 answers to this question
