Developer Wiki and Function Reference Links Read more... ×
STERNontwerp
SetLineAtt - Linestyle bug
@STERNontwerp
It looks like the description for this node is incorrect. If you plug a value in such as -26, you will get a linestyle. The -1 through -8 appears to be outdated from a time before modern linestyles came into place.
I'm going to put a bug in for updating the description as well as a more user-friendly interface for this node.
Thanks for pointing this out!
I'll also create a node for you (hopefully sometime today) that will provide a popup to select the linestyles in our default content.
Great, thanks,
(I could send these things directly to you, but I suppose it is usefull if others can see what is happening)
Ernst van der Vecht
I think it's great that you share your questions with the forum, so no problem there!
In this file, I've created a popup node that references the default line styles, hopefully this can help hold you over while I work out a fix for our default content 🙂
You may need to enter and exit the script of the node to update it to the line styles that shipped with your version of Vectorworks.
Please let me know if you have any questions.
SetLineAtt_iLinestyleQuestion_MFarrell.vwx
Edit: This node works in the English version. In order to use this node in non-English versions of Vectorworks, you may need to edit the filename in the script.
