talene Posted December 9, 2018 Share Posted December 9, 2018 Hi so I have completed a rendering and have it in Narrow Perspective and final quality rendering with the black background on. However, the background is not changing to black. Right now the bottom is a dark green color and the top is white. I have gone into vectorworks preferences and changed the colors manually but still no change. I have also restarted vectorworks but still no change. does anyone know how to fix this? Thanks Quote Link to comment
Kevin McAllister Posted December 10, 2018 Share Posted December 10, 2018 (edited) Are you rendering in the Design Layers or on a Sheet Layer? Are you changing the Renderworks background or the editor background (in the Vectorworks Preferences)? It sort of sound like you're changing the editor background, perhaps using the Preferences>Display>Black Background setting. For rendering, you need to actually set the background using View>Set Renderworks Background. Are you able to post a screen shot? Kevin Edited December 10, 2018 by Kevin McAllister Quote Link to comment
