gravityguy
Instrument Summary 2019 Issue
In my template file I have all Lighting Instruments loaded into a Instrument Summary added and sorted as I would like them to appear. This way when i create a plot I just refresh the summary and bingo i'm done.(layout and fixture order is all as i like it.)
- When updating my template file in 2019 my list is getting cut off at the 87th line. I add Instruments to the list and sort, click ok, then everything after 87th line gets removed from the list.
 - In 2018 I had a list in the Instrument Summary of 109 Fixtures no issues
Anyone else seeing this or have a solution?
Be sure to update to the latest service pack. We found an issue with long lists that should be solved in the most recent service pack. If you still have an issue please submit your 2018 file to support so we can investigate.
Posted (edited)
OK updated to SP2. The issue persists. After I add all the fixtures to the list and click 'OK' the Summary refreshes without the full list i created. Then when i go back into "Build List, I see the attached cut off list.
Thoughts?
Edited by gravityguy
I think there was one more issue we identified and fixed after SP2 was released. The temporary solution is to add an additional item (note, dividing line etc.)  after your last fixture.
Temporary solution does not seem to solve my issue. same results when adding a item at the end.
It maybe something within my file as once i copied a bunch of symbols over to a new drawing and created a summary the list held.
So, what I have done is make a dummy lighting biject named Dummy, and I make sure it's the last item in my lists. When it becomes truncated it does not affect my counts. See the attached screen shot.
