  • 1
Kevin McAllister
Ungrouping PIOs should yield proper 3d geometry
Ungrouping any PIO in 3D should yield proper geometry - solids. It should not result in geometry that is unfriendly to VW. Here's an example where a user's problem should have been able to be solved by ungrouping a Stair -
Unfortunately Stairs ungroup into meshes, probably the most user unfriendly object possible in VW. (Its also the reason stairs don't appear properly when using the clip cube or clip cube viewports, but that's another story.)
Thanks,
Kevin
  • Like 3
1 answer to this question
It's pretty poor that stairs *still* behave like this... this has been highlighted as an issue for ages. It's usually quicker to model stairs from scratch than it is to use the tool as a starting point and then modify.
