Alan Woodwell
Structural & Non Structural Groups
In Advanced section properties you can have separate fills for each type Structural and non-structural ie, Building and furniture. Where is each component defined? or is it by default and can you change the definition of each item say furniture make it structural????
Thanks
Hi Alan
I believe it is the "Merge with Structural Objects in sections" Check box that controls this
1971203195_Skjermbilde2018-12-07kl_10_27_12.thumb.png.9e82d4c68346b9b747bce23d160d54ea.png
Yes, Hans-Olav is correct. It is also pretty well described in the VW Help. Search for Advanced Section Viewport Properties
an excerpt:
Quote
Certain 3D objects can be designated as structural, allowing their appearance to merge with other structural objects on the section plane. Merged objects display as a single unit with one continuous fill. The following objects can be designated as structural by selecting Merge with Structural Objects in Sections from the Object Info palette.
●        CSG solids (add/subtract/intersect/section)
●        Deforms (generic solid)
●        Extrudes
●        Multiple extrudes
●        Extrude along paths
●        Chain extrudes
●        Tapered extrudes
●        Cylinders (extrude)
●        Extruded rectangles (extrude)
●        Extruded polygons (mesh)
●        Meshes
●        Subdivisions
●        Solids (sphere/cone/hemisphere)
●        Sweeps
●        Stair structures (top face, bottom face, front face, inside/outside)
●        NURBS surfaces
I suppose the question is: what is a structural object?
