r.cipriani Posted December 5, 2018 Share Posted December 5, 2018 I need to use Text Along Path in a script. Anyone has an example on how to do? I was'n able to call DoMenuText... Thank you ciao roberto Quote Link to comment
JBenghiat Posted December 5, 2018 Share Posted December 5, 2018 The resulting object is a PIO. Inspect the field names with the plug-in manager. I suspect that the text goes in the profile group and the path in the path group. Quote Link to comment
r.cipriani Posted December 6, 2018 Author Share Posted December 6, 2018 Hi Jos, I don't understand your post. I need to create a Text Along Path using Vectorscript, but I don't found a call nor a menu chunk to insert in DoMenuTextByName(... Quote Link to comment
JBenghiat Posted December 6, 2018 Share Posted December 6, 2018 Text Along Path is a plug-in object, so to create one in VS, you use a CreateCustomObject call, not DoMenuText: CreateCustomObjectPath('TextAlongPath', handleToPath, handleToText); To set parameter values, you use SetRField(). The available parameters for this object are: Text Size Text Type As Height Above Path Rot About Path Quote Link to comment
r.cipriani Posted December 8, 2018 Author Share Posted December 8, 2018 Ok! THANK YOU!!! I now understand how to do! THANK YOU THANK YOU THANK YOU!!! Quote Link to comment
