r.cipriani
Text Along Path
I need to use Text Along Path in a script.
Anyone has an example on how to do?
I was'n able to call DoMenuText...
Thank you
ciao
roberto
The resulting object is a PIO. Inspect the field names with the plug-in manager. I suspect that the text goes in the profile group and the path in the path group.
Hi Jos,
I don't understand your post.
I need to create a Text Along Path using Vectorscript, but I don't found a call nor a menu chunk to insert in DoMenuTextByName(...
Text Along Path is a plug-in object, so to create one in VS, you use a CreateCustomObject call, not DoMenuText:
CreateCustomObjectPath('TextAlongPath', handleToPath, handleToText);
To set parameter values, you use SetRField().  The available parameters for this object are:
Text Size
Text Type As
Height
Above Path
Rot About Path
