cairo9 Posted January 28, 2005 Share Posted January 28, 2005 1. can I select something across all layers.. 2. can I merge to classes.. 3. is it possible to select objects with two dissimilar properties like I want to select all rectangles which are red in color and green in color toger... Quote Link to comment
Travis Posted January 28, 2005 Share Posted January 28, 2005 1) If all visible layers are set at the same scale and layers options are set to Show/Snap/Modify, you can select anything you can see. 2) Selected items can be assigned a class together via the OIP. 3) I don't know a way to specify certain types of object and/or their attributes. There are those among this community who are exceptionally good at scripting, you might try searching/posting the VectorScript board. Good luck, Quote Link to comment
MullinRJ Posted January 29, 2005 Share Posted January 29, 2005 Cairo9, Custom Selection will enable you to do #3 directly, w/o knowing how to script. Goto menu Organize>Custom Selection... If you want to look at the script this will generate, select "Create Script", otherwise leave the selection on "Execute Immediately". When you look at the script, "&" means AND, and, "|" means OR. ("|" is a vertical bar, not a capital "i".) Press the "Criteria" button. You will need 3 categories to get Rectangles with 2 colors, so press the "More Choices" button twice. First Choice: Type - is - Rectangle Second Choice: Fill Back Color - is - RED (choose color from palette) Third Choice: Fill Back Color - is - GREEN (choose color from palette) Check the User's Manual for more details. HTH, Raymond Quote Link to comment
