Selection across all layers
1) If all visible layers are set at the same scale and layers options are set to Show/Snap/Modify, you can select anything you can see.
2) Selected items can be assigned a class together via the OIP.
3) I don't know a way to specify certain types of object and/or their attributes. There are those among this community who are exceptionally good at scripting, you might try searching/posting the VectorScript board.
Good luck,
Cairo9,
Custom Selection will enable you to do #3 directly, w/o knowing how to script.
Goto menu Organize>Custom Selection...
If you want to look at the script this will generate, select "Create Script", otherwise leave the selection on "Execute Immediately". When you look at the script, "&" means AND, and, "|" means OR. ("|" is a vertical bar, not a capital "i".)
Press the "Criteria" button.
You will need 3 categories to get Rectangles with 2 colors, so press the "More Choices" button twice.
First Choice: Type - is - Rectangle
Second Choice: Fill Back Color - is - RED (choose color from palette)
Third Choice: Fill Back Color - is - GREEN (choose color from palette)
Check the User's Manual for more details.
HTH,
Raymond
