  • 4
Christiaan
Please stop mouse zoom 'skidding'
This has been an annoying problem for many years and I've finally got round to posting a wish because I'm working on a particularly big project, so it's very pronounced.
When using the mouse to zoom in or out I often find that VW doesn't respond if the cursor is located over objects on the screen.  Move the cursor to a clear space and zooming is far more responsive. Hence 'skidding', as it kind of feels like you're doing a burn out on the mouse wheel or touch zone.
Please eliminate this.
Edited by Christiaan
6 answers to this question
Yes, that can be terrible hindering in crowded Files.
And it is often hard to find an "empty" space in your Model.
(I had oped there would have come a solution for this over the years - not ?)
I think it has to do with Object Selection/Highlighting/Snapping which seem to
have priority over and stop View Navigation Commands as long as they are
occupied ....
I didn't experience that issue in the past again because my projects were
moderate in size again. So no suitable Demo File here to test.
But while thinking about it,
have you ever tried to Zoom, while holding the Snapping Pause Key ?
(If that will work at all at the same time ?)
To test if it has only to do with Snapping ...
And Maybe one could try if Zooming works better when all Highlight Features
deactivated in VW Prefs ?
22 hours ago, Kevin McAllister said:
I'm sure its related to selection highlighting still being single core.....
You got it. This limitation will indeed be removed and things will become much snappier.
Disabling selection highlighting entirely helps, but I can't personally tolerate just the selection handles unless I'm doing a demo and not modeling things. My first version was Vectorworks 12.5 so I got used to the highlighting in 2008 right away and have relied on it ever since.
I work with pre-selection highlighting disabled and its a much better workflow in high geometry situations. Not sure if its still turned on by default. Ironically you don't really need it anyway since snap highlighting does the same thing. Both of these systems can really bog things down especially on a sheet layer with a lot of camera viewports. There could be some unification of how all this works.
VW12.5.2 was the most stable version of VW I remember. VW2008 was not a great experience for me and many others. It upped the system requirements substantially (sort of like the last couple of versions) and many people had trouble with things like pre-selection highlighting and snap highlighting.
Kevin
