Popular Post Kevin McAllister Posted November 30, 2018 Popular Post Share Posted November 30, 2018 There should be a way to pull the combined data from the new Data Tag into one unified worksheet. Here is an example of what I mean - As far as I can tell this is currently not possible. There have been at least two forum posts asking about this so far - I'm very surprised this wasn't considered in its design. Thanks, Kevin Data Tag Wish.vwx 8 Quote Link to comment
0 ericjhberg Posted December 1, 2018 Share Posted December 1, 2018 @Kevin McAllister I think that this is a great request. I haven't yet played around with the Auto-Generated Incremented Value options yet and instead have been relying on a manually entered ID# in the attached record to handle the appearance of the tag, while querying the record format to the worksheet. This requires me to manually adjust the values, but I can easily do that from the worksheet and thus it hasn't been to bad. A couple of questions about the Auto-Generated Incremented Value. Does it recognize similar objects with similar data, giving them the same number? This would mean that the auto number is recognizing that the data/object is different somehow? I initially conceptualized something like this, but that would take advantage of the callout tool and keynote legends instead, which already have the auto-numbering built in. Perhaps there is a way to combine these functionalities, because Keynote Legends are actually a pretty good way to manage auto-numbering. Perhaps the Data Tag could be designed to send a specific field to a keynote legend and then auto-number based upon that legend? Ultimately you are correct, you would still need a way to pull this number into a worksheet. We do this currently with callouts using the formula (='Callout'.'__KeynoteNumber')...something I would have never discovered without the help of wizard @Pat Stanford. ...Hope that they can integrate your suggestions on leader lines as well! ...and multiple leader lines. Quote Link to comment
0 andreikremnev Posted January 31, 2022 Share Posted January 31, 2022 I believe this has not yet been implemented. I've been sitting for 4 hours trying to figure out what takes a minute in Revit and Archicad!!! Colleagues hear requests! Quote Link to comment
0 Vectorworks, Inc Employee KIvanov Posted February 1, 2022 Vectorworks, Inc Employee Share Posted February 1, 2022 Hi All, This is a short video how you can put the extracted data into a record attached to a data tag and then to list it in a worksheet. Best Regards, Kostadin Ivanov Data Tag.mp4 2 Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted February 1, 2022 Vectorworks, Inc Employee Share Posted February 1, 2022 Hello all, You can also use the DataTagField worksheet formula on a database worksheet of data tags. Best Regards, Nikolay Zhelyazkov 2 Quote Link to comment
0 Boh Posted June 30, 2022 Share Posted June 30, 2022 On 2/1/2022 at 11:31 PM, Nikolay Zhelyazkov said: You can also use the DataTagField worksheet formula on a database worksheet of data tags. Hi Nikolay. Can you please explain what the "criteria" is in this formula? I want to get the incrementing value integer of a data tag into a worksheet and I can't figure it out. Thanks Quote Link to comment
0 Vectorworks, Inc Employee Nikolay Zhelyazkov Posted June 30, 2022 Vectorworks, Inc Employee Share Posted June 30, 2022 1 hour ago, Boh said: Hi Nikolay. Can you please explain what the "criteria" is in this formula? I want to get the incrementing value integer of a data tag into a worksheet and I can't figure it out. Thanks Hello @Boh, The criteria is for selecting on which objects to apply this function. If you use database worksheet of data tags, then the criteria is automatically passed and you do not have to specify it. What you need to enter is fieldName, which is the value of the text object inside of the data tag layout, which you want to display in the worksheet. Example file attached. Best Regards, Nikolay Zhelyazkov DataTagFieldExample.vwx 2 Quote Link to comment
0 Pat Stanford Posted June 30, 2022 Share Posted June 30, 2022 To expand on Nikolay's comment. Many of the Worksheet Functions can be used in individual Spreadsheet cells or in Database Header cells. If they are used in a Database then the criteria from the database will automatically be passed with one object being passed for each subrow. If they are used in a Spreadsheet cell then you have to supply the criteria. Let's say you have a bunch of lines in a class named Boh. Create a Database Row and Set Criteria to: This gives you a formula for the database of =DATABASE(((T=LINE) & (C='Boh'))) With ((T=LINE) & (C='Boh')) being the criteria. This is great. It will let you have a subrow for every object that meets the criteria and you can display different information about each object in different columns. If you want the length of each line you can use a formula of =Length. But what if all you want is the total length of all these lines? It seems a waste to make a database to do that. You can just put a formula in a spreadsheet cell of =Length(((T=LINE) & (C='Boh'))) Now back to data tags. If you had a number of different data tags, but knew they all had the same value you could use a spreadsheet formula like: =DATATAGFIELD((((PON='Data Tag') & (C='Boh'))), 'PTS') But I am not sure how much good that would do you as it seem to return the value of the first placed data tag for the field named PTS. The Field Name is the text string in the Data Tag Layout that is linked to Dynamic text. I was hoping for functionality like the ability to SUM the values of multiple data tags or to show the value if all the Data Tags specified by the criteria were the same and a dash or some other indication that the values were not the same across all the tags that meet the criteria. HTH. 2 Quote Link to comment
0 Boh Posted August 18, 2022 Share Posted August 18, 2022 Apologies for late response to this but thank you @Pat Stanford & @Nikolay Zhelyazkov that was very helpful!. Thanks Quote Link to comment
Kevin McAllister
Thanks,
Kevin
Data Tag Wish.vwx
8 answers to this question
