Ryan Seybert 27 Posted November 29, 2018 I have a motor point picking an audio array and the load weight is off by 262lbs. 1/2 Ton motor = 100lbs. Audio Array = 914lbs. Total Point Load = 1,014lbs. Braceworks is calculating a load of 1,176lbs. with an excess of 262lbs., roughly 28.67% of the load. Not sure where its coming from. It also seems to scale larger when the load becomes larger. I changed the array so that it was a flat 1,000lbs. The excess grew to 350lbs., 35% of the load. I've attached some screenshots for clarity. Any help would be greatly appriciated. Quote Share this post Link to post
J.cole 1 Posted December 15, 2018 Check your BraceWorks Preferences. What are your safety factors set to? 1 Quote Share this post Link to post
