Kevin Friddell Posted November 28, 2018 Share Posted November 28, 2018 (edited) I was wonder it is possible to get better resolution from renders, and how to remove noise from said renders. (See the white specs on the bottom right render. Edited November 28, 2018 by Kevin Friddell Quote Link to comment
EAlexander Posted November 28, 2018 Share Posted November 28, 2018 For resolution - are you rendering to viewports on a sheet layer? If you right click on the name of the sheet layer in the navigation palette and choose edit - from there you can up the resolution of the sheet layer. It defaults to 72dpi, so very low. try 150 or 300 depending on your needs. I assume the white sploches are from the blurry reflection on the floor needing higher quality settings. If you edit your renderworks style - you can up the quality of blurriness. Start there and see if that helps. It will add to render time. 2 Quote Link to comment
Kevin Friddell Posted November 29, 2018 Author Share Posted November 29, 2018 Thank you Evan. Quote Link to comment
