VW19 - DWG import generates strange result
bjoerka
4 answers to this question
oh wow. dwg into 2017 was never a problem at all.
also when i import this specific file into 2017 and 2018 it appears to be ok.
thanks for the workaround.
another one is to edit the symbol, nudge the geometry with the keyboard right and left and exit the symbol.
after that the ghosting disappears (mostly) too.
but i am aware to do this with huge dwg imports...
hopefully things in 2019 will speed up with the upcoming service packs... sp2 is terrible slow...
Hello bjoerka,
I believe, that this problem was already for sp3. It is related to the proper regeneration of the drawing - i.e. objects are imported correctly, in their right positions, but due to a missing drawing regeneration graphics does not look as expected. This additional regeneration was not necessary in previous versions, but for VW2019 it has to be done. This problem appears only for some files, which is the reason to not been found and fixed earlier.
For now I could propose two workarounds:
1) Import the DWG in Vectorworks and immediately after the import has finished, without switching to another layer or zooming, save the document, close it and then open it again - everything should be regenerated correctly.
2) Import the DWG using the Location import option "Align with Internal Origin". Graphics will be drawn correctly. If you need the drawing to be centered, then use the menu command Tools-->User Origin-->Center Drawing on Internal Origin. (Note: Importing with Location option "Center first import, align..." (for a first import) or "Center on Internal Origin" are equivalent to importing with Location option "Align with Internal Origin" PLUS using the menu command Tools-->User Origin-->Center Drawing on Internal Origin.)
If you still have a problem using the workarounds, please, send the DWG file directly to me.
Best Regards,
Nina
