jnr 101 Posted November 26, 2018 Not sure what I'm doing wrong. Am able to right click, and modify proposed site contours in a model except one of them keeps reverting back to its original state after moving or deleting vertices. the misbehaving contour is very close to a pad modifier. Any one else had this? Quote Share this post Link to post
rowbear97 49 Posted November 28, 2018 @jnr I have had this issue in 2018 and to a lesser degree in 2019. I have given up on VW creating smooth proposed contours and regularly draft contour site modifier objects to get the desire result. It could be that there are some points that are corrupting the site model. Quote Share this post Link to post
jnr 101 Posted November 28, 2018 Rowbear, why am I not surprised? Once the project settles down a little, I'll go in and set the contours a mano. ugh. Am also unable to select a site modifier in 3d, having to toggle back to plan before I can select it. It's a PIA. Didn't used to happen in 2018. 2019 has turned out to be a glitch-fest. Get all sorts of weird graphics behavior with rotated plans, viewports, image effects etc. And this is with a 16gb graphics card. It ain't the hardware. Quote Share this post Link to post
