Function "IF" help please
techdef
_almost_ got my building space/area calculator working but am getting a #/DIV 0! error (legitimately) when dividing an Area by an occupancy of 0. The zero is coming from ='Space'.'SpaceOccupancyRequirements_AreaPerOccupant'
Trying to avoid that by :
=IF((L6=0), 0, F6/L6)
Somehow that still gives the div/0 error when there shouldnt be any division happening!? Ive tried adding ' marks to the zero to no avail.
Edited by techdef
5 answers to this question
hmm, that doesnt quite align with the way I read the man files & the example:
if ((logical_test), value_if_true, value_if_false)
Use value_if_true if logical_test is true, value_if_false if logical_test is false.
Use this function to conduct conditional tests on values and formulas and to branch based on the results of that test. The outcome of the test determines the value returned by the If function. The logical_test can be any value or expression that can be evaluated to true or false. Up to seven If statements can be nested as value_if_true, value_if_false arguments. Boolean statements within an if statement must be in parentheses. Text within an if statement should be enclosed within quotation marks.
Examples:
●    =if(('Existing Tree'.'Condition'='Not Set'), '-', 'Existing Tree'.'Condition') If no condition value was set for the existing tree object, the value in this cell is a dash; otherwise, the value in this cell is the condition value that was set for the tree object.
IsError and SumIf seem painfully missing!
Finally have a workaround. Next time you seek an IsError function try something like this:
=IF(L18>=0.01, M18, 0)
This evaluates L18 as being a positive number. If it is, then M18 is the answer, if not, it shows 0. Turns out a div/0 error is less than 0.01, so this if test works and shows a zero instead of an error message.
Edited by techdef
I have a similar problem with the #DIV0! on a vw spreadsheet. Have tried using the IFERROR function to get rid of it which doesn't seem to work in VW. Then tried @techdef's workaround. Unfortunately that didn't work either.
I've created a seperate thread on this. Would appreciate any help! Thanks
