Antoine D'Halluin Posted November 20, 2018 Share Posted November 20, 2018 Hello, I have strange behaviour when trying to connect 2 trusses with dead hang or hoist : If I plot on true at 10m, another at 8m rotated 90° ; I can select insert connection tool ; select one truss & then the other one. Then, the 2 trusses or connected. ==> OK If I suppress the hoist or the dead hang (with "suppr" or "<--" keyboard key) ; I reselect the connection tool ; I can select any of the trusses for first connexion but when tool activated & link to first one, I cannot click on second truss ; it never switch to "red select" status (see picture enclosed). So I can never reconnect the 2 trusses. As if a connexion was still existing... I am using the wrong way the tool ? Do I have to reset something ? purge physical connexion somewhere ? I showed to several colleague ; none of them ever experienced that... Should I reinstall VW ? thanks for advices Quote Link to comment
Guest Beckstorm Posted November 20, 2018 Share Posted November 20, 2018 I am not sure I understand you completely but is this what you are trying to do? Insert connection.mov Quote Link to comment
Antoine D'Halluin Posted November 20, 2018 Author Share Posted November 20, 2018 Hello Brandon, thanks for your answer & video. yes I am exactly trying to connect with a hoist or dead hang as first exemple. first try is ok ; but if I have previously linked trusses, I cannot re-link them again. see video below bracework link 720p.mov Quote Link to comment
Guest Beckstorm Posted November 20, 2018 Share Posted November 20, 2018 That is a bug I will let the engineers know, thank you for reporting it. Quote Link to comment
J. Miller Posted February 9, 2019 Share Posted February 9, 2019 So what’s the trick to fixing that? delete redraw, restart, etc? i have this problem too Jeff Quote Link to comment
