halfcouple
Select Similar tool inside Clip Cube
How about this:
There should be an option in the select simlar tool settings "This selection affects only objects within the clip cube range". There are often certain objects which need to be selected out, that are in a defined aerea on a layer, but not all of these objects on a layer should be selected. Clip Cube would be the ideal tool to define this aerea.
1 answer to this question
Just stumbled over this, maybe someone here finds it helpful:
The Select Similar tool has two modes: The second mode is to search only within selected objects, so when selecting all objects within a clip cube the Select Similar tool can affect only these objects. So no need to have a special tool for this.
