  • 1
Symbol Images Disappear in worksheets
lgoodkind
When placing a worksheet on a sheet layer - and that worksheet has image functions showing graphic symbols - unless the class(es) of the symbols are currently turned on they will not show up.  This is really bad.  Obviously if you are inserting a worksheet on a sheet layer it shouldn't matter if the class the symbols are on are currently turned on or not since this is controlled through the viewports.  Or maybe I'm missing something?
Vectorworks please change this error/
Edited by lgoodkind
3 answers to this question
Occasionally symbols may contain some information on "NonPlot" classes which you wouldn't want to see in the worksheet image, so this is a good reason for the images classes visibilities to be controlled through the current class visibilities.
What about putting the worksheets inside a viewport and having the viewport visibilities control the image classes?
