  • 3
mbft
Structural Member Tool
Structural member tool : DIN series beams are not correct.
If I try to draw an HE-A 220 which should be 220mm a beam that is 1008mm appears
There seems to be only one size beam available in the DIN series.
I have signalled this before. There is a problem with the text file database for the series. It would be much appreciated if VW  could fix this.
StructShape_WFlange-DIN_original.txt
StructShape_WFlange-DIN.txt (this is a modified file that I created)
Edited by mbft
2 answers to this question
@mbft just a heads-up this should be fixed in SP2, so if you're still seeing problems please let us know.
Can you check the wide flange tool and see if the problem exists with profiles in there also? @mbft
As I'm aware (and I might be incorrect) it looked like the profile sizes were ported over from the wide flange tool, into the structural member tool
I've raised a ticket about this tool regarding missing UK profiles, and have added your feedback to that ticket.
VB-153727
