Cris with no H Posted November 12, 2018 Share Posted November 12, 2018 So I've figured out how to specifiy more than one record in my database criteria. But I can't seem to specify a list of layers. For instance, I want to pull data from Seating Sections spread across 3 layers. In this way I exclude the seating sections on other layers I don't want to count. Any advice? Quote Link to comment
TKA Posted November 13, 2018 Share Posted November 13, 2018 it depends which version of Vectorworks you are using. Normally there is an option to add layers and other criteria from pull down menus. Quote Link to comment
Boh Posted November 13, 2018 Share Posted November 13, 2018 Maybe I've misunderstood but, in the criteria dialogue can you not just keep adding an additional choice for each layer for which you want to select objects? I thought that if the object criteria are mutually exclusive then it will select objects that conform to both criteria - an "or" scenario (in this case layers). If the criteria is not mutually exclusive then it is an "and" scenario, i.e. only objects that conform to all criteria are selected. Quote Link to comment
Jonathan Pickup Posted November 13, 2018 Share Posted November 13, 2018 13 minutes ago, Boh said: Maybe I've misunderstood but, in the criteria dialogue can you not just keep adding an additional choice for each layer for which you want to select objects? I thought that if the object criteria are mutually exclusive then it will select objects that conform to both criteria - an "or" scenario (in this case layers). If the criteria is not mutually exclusive then it is an "and" scenario, i.e. only objects that conform to all criteria are selected. I think Boh is right with this. Quote Link to comment
TKA Posted November 13, 2018 Share Posted November 13, 2018 Boh, you are right, I have misunderstood your question, may be if you . What I understood is that let's say you have 6 layers and 3 different types of seating spread across all layers. You want to have box in a spreadsheet showing just type 1 seating on layers 1,2,3, that will be scenario where both chair type and layer will have to be present in order to register in the box. But I suspect you might have something else in mind. Quote Link to comment
Cris with no H Posted November 13, 2018 Author Share Posted November 13, 2018 Ah.... I will have to try that Boh. Thank you! TKA, that's pretty much the scenario. Needing to pull data from multiple (layers / classes / records / types /etc) take your pick. And combinations of those multiples. I sense myself headed down the rabbit hole of worksheets, but boy it sure has come in handy lately, except that some of my longer worksheets could be more compact by using a multiple data scenario like this. Quote Link to comment
TKA Posted November 13, 2018 Share Posted November 13, 2018 take a look at this, this is a schedule of different light fixtures on a number of floors, is this what you are trying to do? Quote Link to comment
Cris with no H Posted November 15, 2018 Author Share Posted November 15, 2018 TKA, that's not quite it. That looks like it's using =L in the database header of column K. I need to specify the Criteria for the database row as something like "look only on layers 5 and 7 for all objects with Platform &/or Deck records". the records part I have figured out. But the way of specifying a list of records doesn't work to specific a list of layers, too. Quote Link to comment
Cris with no H Posted November 19, 2018 Author Share Posted November 19, 2018 So it seems it really was as simple as specifying both layers in the criteria. For some reason, I always thought the criteria was exclusively an AND operation and that specifying two layers would result in nothing. My criteria line looks like this: =DATABASE((((L='HOUSE') | (L='FOH')) & ((R IN ['Seating Section']) | (R IN ['Event Planning Record'])))) So I guess the | symbol works as an OR function. 1 Quote Link to comment
