Scaling trees
Sade
I wonder why the VBVisual Tree is of scale at all.
Is the Plan behind a Design Layer Viewport ?
(and is that at Scale ?)
As the VBVisual Trees are Parametric and have chosen a certain Tree Size.
If it is really the Tree which is off Scale, you could maybe create a Symbol
from it and adjust the Symbols Scale for each Instance you insert.
If that does not work you could "ungroup" the parametric Tree Object
to extract the Geometry before creating a new Symbol from it.
