Steven Morgan Posted November 9, 2018 Share Posted November 9, 2018 (edited) Searched the forum and couldn't find anything. I have a bunch of default instruments in spotlight that bring in some numerical data as text. ( 93lbs instead of 93). Rather than changing all of my records is there a way to strip out a string of text from a worksheet column? If I could remove 'lbs' and 'watts' and return only numerical data I would be in good shape. Thanks! Edited November 9, 2018 by stevenmorgan94 Quote Link to comment
Pat Stanford Posted November 9, 2018 Share Posted November 9, 2018 Try Value(SubString(Cell Reference Containing Text Data, Delimiter, Position)) If B3 Contains 93lbs, the cell containing =Value(Substring(B3, 'lbs', 1)) Should display as 93 formatted as whatever number type you want. Quote Link to comment
Steven Morgan Posted November 9, 2018 Author Share Posted November 9, 2018 Thanks Pat! Kickass class this week at VWX Summit. Quote Link to comment
Steven Morgan Posted November 21, 2018 Author Share Posted November 21, 2018 Digging this one back up. I am trying to get the total weight of this column. I am able to strip away the 'lb' using Pat's formula above, however I can't total the column. I have tried: =SUM(G4.1..G4.4) However I don't think you can select sub-rows using the range symbol. Also tried: =Value(Substring(G4, 'lb', 1)) Obviously it just returns the '4.00' which is the count of the column. I can't find a way to only apply that to sub-rows. Any ideas? Quote Link to comment
michaelk Posted November 21, 2018 Share Posted November 21, 2018 Is this with spotlight instrument objects? Quote Link to comment
Pat Stanford Posted November 24, 2018 Share Posted November 24, 2018 the 'Lighting Device'.'Weight' field is text not a number that is why it won't add up. If you are OK with not being able to change the weight from the worksheet try using =Value(Substring('Lighting Device'.'Weight', ' ' ,1)) Note that there is a space between the single quotes after the field name. If you want to be able to make changes from the worksheet you will have to use two columns. Put the Record.Field into one cell and then reference that cell in the Substring call. You can use the Format Cell Trailer to add the 'lb' back into the display if you want. Quote Link to comment
markdd Posted September 10, 2021 Share Posted September 10, 2021 @Pat Stanford Can you use the Substring to strip all text from a field. Sometimes I have Watts wrongly abbreviated as a lower case W. It would be great to remove either 'W' or 'w" or 'kW" Thanks Mark Quote Link to comment
Pat Stanford Posted September 10, 2021 Share Posted September 10, 2021 Like all things, it depends. If the data is coming from a record.field, then substring will not help. If the data is just text then maybe, because you have to have some kind of a delimiting character. Would a script to edit the data attached to the objects be a better option? Tell me more about how you need your data fixed. Maybe in a new thread. Quote Link to comment
