cberg Posted November 7, 2018 Share Posted November 7, 2018 (edited) This is probably an easy question, but I would like to make invisible all the stray lines associated with a stair and only have treads (so the object can be parametric). Is there any way through the control of class visibilities to hide all the random construction geometry. I tried, but couldn't figure it out. stair v2018.vwx Edited November 7, 2018 by cberg Quote Link to comment
cberg Posted November 7, 2018 Author Share Posted November 7, 2018 I figured it out. Under stair structure, truning off the stair structure lineweights produces the desired result. 1 Quote Link to comment
Markvl Posted November 8, 2018 Share Posted November 8, 2018 Hey @cberg could you not assign the different elements of the stairs to their own "class"? As per your screen shot the whole stair is on the same class...<stair class>. Classes will work far more quickly to turn on and off as you please. 1 Quote Link to comment
