Wall tolerance
rebu1985
Hi guys,
I would like to know if there is anyway to indicate tolerance in walls. When i have created walls in different layers or stories, the front view shows a line between them when they should be aligned.
You can find below an image of my elevation where i have indicated in yellow the line as partition wall when it should be continuos because they are in the same plane (aligned).
Thank you guys,
