3D Views in 2019
Hi all,
this problem has probably been addressed before, but I'm having issues with modifying things in 3D views (specifically, from the right) in VW2019. I switch to the right view, and all my stuff disappears. I'm in Wireframe rendering, and I use the X-ray feature (holding B) and nothing happens.
I was out of the game for a while (really proficient with 2008) and getting back in 11 editions later has some growing pains.
Basically, how do I create an extrude in plan view, then switch to view from the right and keep modifying it?  It feels like it should be a simple fix.
Thanks.
Is the object just off screen after you switch the view? If you have the extrude selected before you switch view try Fit to Objects and see if it shows up. Or zoom way out until it shows up. And then back in on it.
There is also an option in VW Preferences, Display Pane to Center on Objects after View Change. This might solve you problem as well.
