Julian Carr
Accessing and Creating Resource Folders
Has anyone figured out how to create a resource folder (other than a symbol folder [type 92]), and if so, what are the Object Type numbers for the various types of resource folders?
[Edit]: Actually all resource folders are type 92, and I have tried using SetParent(), but that doesn't work to put resources into resource folders.
Thanks!
Actually, one more. Any ideas for an equivalent to InsertSymbolInFolder() for shifting imported resources to a designated resource folder? InsertSymbolInFolderN() seems to be accepted by the compiler, but doesn't do anything and is not in the Function Ref.
SetPsrent() should work, and I believe you can get a handle to the folder with GetObject().  If you do an error check, the folder type will always be 92, regardless of content.
Thank Josh. Yeah I tried that already but unfortunately it doesn't do anything in this case and the function returns false.
