Shani
trees in sheet layer
i have inserted 2d tree symbols from the ozcad library into design layers but cannot view these in sheet layers, i have the correct layers enabled in the viewports and all the linework from these layers is visible, is there a setting that i need to change?
also is it possible to sacle 2d symbols in a design layer? to get a smaller version of a tree i have had to bring the symbol in on a different scaled layer.
You can duplicate a symbol and scale the duplicate, by going to the edit dialog in the resource palette and then scaling components that make up the symbol.
Does the symbol have a class not active in the viewport?
If you added the symbol to your design layer after the viewport was created any new classes in the symbol won't be active in the viewport.
