Cris with no H
Planar objects showing in RW modes
I have a file that I've rendered side by side in 2018 and 2019.  In 2018, the planar objects disappear as I expect them too.  In 2019 - directly opened from the 2018 file, the planar objects pop back into existence at the end of the render.
Is 2019 supposed to do this?
Yes! Beginning with version 2019, Renderworks modes show all planar objects and point clouds, with the exception of Artistic RW and RW styles with edges.
  • Love 1
Cris - do you already have the "Display Planar Objects" button unchecked in the Viewport's OIP? I'm assuming you're rendering in viewports....
If this is unchecked and planar objects are still rendering (which has happened to me once in 2019), then it sounds like a bug.
This is not a viewport.  This does not make me very happy, @Selin.  This should at least be a preference.
Edited by Cris Dopher
The planar objects always disappearing in renders was indeed a bug. If your workflow had included this as a part of it, your easiest option is to render in a viewport so that you can control it's visibility. Rendering in a viewport is better for a number of reasons, this included.
Yep, it was a limitation of the CineRender engine. Sorry to hear that it was part of your workflow.
I don't need (or want) that either.
And now I know I have to better care about it.
Should work as I have my few 2D Elements on separate Classes.
But I am very happy for all the Students on the german VW Forum,
as they always tried to render their 2D PDFs under their 3D geometry.
I see 2D is not effected by Shadows and GI (?)
Nope. 2D geometry is rendered with OpenGL and won't affect the RW renderings in any way.
However this is quite a nice Effect to add some fancy details by adding a bunch of Lines here and there ...
Edited by zoomer
If only VW could accept that "open" Polylines could never have Fills ....
rendering in a viewport might be better, but it doesn't contribute to efficiency.  On the design layer, I can continue to make changes as Renderworks plugs away and it will restart the render when a resource is changed.  It is just quicker on DLs.
However, I've found a workaround, thanks to Selin's first comment:  I set up a RW Style that this time includes edges, just set to 0 pixels.  Voila.
Hahah I like this workaround 😄 much quicker than setting classes.
